Change data format (from devices mess to dec?)
Hi all!
Problem: I get data from device (serial) and it looks like this in string-display ¿Ww¿a¹¢¿fÚñ¿‡ò¶¿ but when i am changing displays mode to HEX it looks fine and data is correct. Now i have a problem how to change that HEX data to decimals automaticly when get it on the device. How to change ¿Ww¿a¹¢¿fÚñ¿‡ò¶¿ data to HEX somewhere else than on display (modes)? And handle it in HEX format? not in Ww¿a¹¢¿fÚñ¿‡ò¶¿ format.
Thank You!
(2,969 Views)
Accepted by Alias A
Its here.....cheers Smiley Happy
Message Edited by JK1 on 05-27-2009 03:57 AM
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,954 Views)
Use the "String to Byte Array" function located in String/Array/Path Conversion menu to convert to decimal.
-Vikas
(2,952 Views)
I often use the type cast function. It is useful if the "string" received is say an array of I16 integers.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,948 Views)
Works fine.. thanks alot 🙂
(2,927 Views)
