Change a lot of font properties at once
Changing font properties has always been a P.I.T.A. as the only way I have been able to do it is one at a time highlight every label, decal, or string one at a time and set the properties...
I know, I know, if I had set the panel defaults before I started then I would not have to changes every single label from 14pt Segui to 18pt Tahoma one at a time...
But when you have a program that was created on a Windows 7 machine and move it to a Windows 10 all of your fonts are the wrong size now, even on the block diagram.
So what is the fastest way to fix a screen full of fonts?
=== Engineer Ambiguously ===
(1,813 Views)
Accepted by RTSLVU
Ctl+a to select everything, then set the font.
(1,810 Views)
I set the fonts in LabVIEW options in the Environment category for application, dialog and system fonts to Tahoma 13. For the controls and indicators that are shown to the user, I set the font for each (also to Tahoma 13) by selecting the control and then the font from the toolbar. In this way I don't have any issues with fonts in IDE and exe.
Lucian
CLA
(1,791 Views)
