Change Printers
Here is a picture to show getting the printers list and default printer from registry keys. Not sure if these vi's are in 6.0.2
Message 11 of 20
(1,485 Views)
Yes, it work. I'm tried to set the printer, but I'm not sure if it is right and I want play with the registry. Can you check it uncledump?
Message 12 of 20
(1,472 Views)
Thanks Donald, that works. Not as clean as I want, but I can choose the Printer.
Message 13 of 20
(1,467 Views)
Another alternative for LV6.0.2 may be the two VI's that Jean-Pierre Drolet posted at the end of a thread  here  in 2001 which use Active X/Windows Scripting Host Object.
Fading out. " ... J. Arthur Rank on gong."
Message 14 of 20
(1,458 Views)
Here is a version that uses prnmngr.vbs to read the printers list, then the default printer, then change the default printer to a different printer. This is a 7.0 format file. I also saved two graphics of the block diagram. I could not save it back to 6.1 due to changes in the system exec vi.
Message 15 of 20
(1,450 Views)
Try this file in 6.0 format. I saved it back two versions so I'm not sure if it is runnable when opened. If not, the system exec.vi may need to be fixed in three places.
Message 16 of 20
(1,448 Views)
Or you can use Window API call.  GetDefaultPrinter & SetDefaultPrinter are very simply calls.
See attached llb.
George Zou
George Zou
Message 17 of 20
(1,446 Views)
Thanks to all. All you gave me worked!
Message 18 of 20
(1,419 Views)
Hi !!
I want send to printer a file text from LabVIEW , you can help me  please
Note: Sorry for my bad write English, so I speak spanish
Message 19 of 20
(1,410 Views)
Hi Andres,
try it with this VI. It should print to de default printer!
Message Edited by Petric on 09-23-2005 07:51 AM
Message 20 of 20
(1,405 Views)
