Change LabVIEW Registered Owner and Company
@RavensFan wrote:
Nickerbocker,
Which OS are you using?  I'm using XP.  I don't see a c:\programdata folder even though I have my explorer set to show all hidden files and folders.
I'm on Windows 7 64bit.
I think that ProgramData in Windows XP is in C:\Documents and Settings\All Users\Application Data
Run this VI and see what the results are:
Message 21 of 25
(3,218 Views)
Nice.  The c:\docs and settings\all users was the secret for XP.
Now I can fix that on a machine or two where I don't like the way it chose it.
Also, I see the S/N is stored in there.  It looks like that would be a good place to delete that so that you can hide the serial number on start in the event you take a screen shot or take a video of LV.
Message 22 of 25
(3,202 Views)
Changing the keys specified in this article didn't work:
http://digital.ni.com/public.nsf/allkb/955FF9EB1DEFCDCE86256AD900763026
While this might not work for newer LV versions, it worked perfectly for our old LV8.5 systems. On those, the folder LVProductDLLinfo does not exist in the OS-respective file system hierarchy. Changing the entries in those RegKeys solved the issue of modifying the splash screen info for LabVIEW.
Message 23 of 25
(2,830 Views)
@hecmar.arreola wrote:
Ok, NI support helped me out on this one.  Updating the .ini file from within C:\ProgramData\ ... fixed the splash screen and also now when I create a new build my company name is auto-populated in the Version info.  Thanks, NI!
1) Navigate to C:\ ProgramData
2) This folder is hidden and you must select Tools » Folder Options » View » Under ‘Files and Folders » ‘Hidden files and folders’ » check the ‘Show hidden files, folders, or drives » Select ‘ok’
3) Open ProgramData » National Instruments » LVProductDLLInfo » 12.0.0 » LabVIEW_ADE_120000.ini
4) Change the RegisteredOrganization = ‘xxxxxxx’ to the appropriate organization
5) Change the RegisteredOwner = ‘xxxxxxx’ to the appropriate owner
This will change the LabVIEW splash screen to the appropriate settings.
Thank you!
Message 24 of 25
(2,787 Views)
Does anyone know how to do this for newer versions such as LabVIEW 2020? This worked for me for LabVIEW 2014, but there are no corresponding folders for the LabVIEW 2020 installation that I have.
Is there no way to change this information now besides activating the software with an ni.com account that has the name displayed exactly how you want it be? (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8FeSAK&l=en-US)
Message 25 of 25
(2,493 Views)
