Case structure with separate buttons to trigger individual cases?
Yes, since the case should only execute once and then wait again, an event structure is more appropriate here.
A few comments.
  • You don't need the wait because the loop does not spin unless needed.
  • You also need to add an event for the stop button.
  • You could combine all buttons into one event case to simplify the code.
  • How often do the address, resource, and output of the prologix subVI change? If they are static during the subVI execution, they belong before the loop.
Message 11 of 13
(1,308 Views)
Accepted by topic author martinv
Here's one possible solution to keep it all in one event case for simplified editing. (I made some other assumptions, so modify as needed).
Message 12 of 13
(1,299 Views)
Thanks for additional comments and the vi.  It was very helpful.
Message 13 of 13
(1,272 Views)
