Case structure duplicates all indicators on the user interface.
I am creating a true/false case structure which contains multiple indicators for each case respectively.  These indicators are being shown on the user interface simultaneously.  Is there a way to have the indicators replace each other as the other case is active or do both indicators and/or controls have to be on the user interface simultaneously?
Thanks!
(2,487 Views)
No, you can hide indicators with the Visible property but why use separate ones? Why not just write to the same?
(2,483 Views)
Accepted by topic author frabie
Is there a reason you want to duplicate the indicators?  Normal practice is to move the indicators outside of the case structure and the wire coming from each case coming out by way of a tunnel.
(2,468 Views)
Thanks guys!  I simply moved the indicators out of the loop and it worked perfectly.  Yes I am a beginner but I'm learning 🙂
(2,458 Views)
