Hmm,
that one not so simple for ranges...
The correct syntax for string ranges is "00".."09" but remember that the
range spec is upper bound EXCLUSIVE for strings. The range "00".."0F" thus
corresponds to an integer range of 0..14 beacuse "0F" is not part of the
string range. You enter an inclusive range 15 putting the upper bound
explicitely "00".."0F","0F". Otherwise, since "A" is lexically greater than
"9", there is no problem.
Since string selectors support \ codes, another way is to flatten you number
to string and type in your cases as "\00".."\FF" for U8 numbers,
"\00\00".."\FF\FF" for U16 and "\00\00\00\00".."\FF\FF\FF\FF" for U32. The
upper exclusive rules for strings still applies.
Jean-Pierre Drolet
"Craig Graham"
@lancaster.ac.uk> a écrit dans le message news:
3a90f484@newsgroups.ni.com...
> This won't let you do things like "00-09" "0A-0D" "0E..." though, since
the
> numerical "meaning" is lost.
> Jean-Pierre Drolet wrote in message
> news:3a8dc3b0@newsgroups.ni.com...
> > You can format the number in an hexadecimal string (for example %02x)
and
> > input this string to the case selector. Change the cases to "00", "01",
> etc.
> > Jean-Pierre Drolet
