Case Structure in While Loop for DAQ
Hello, I am writing a program and I am not very familiar with how to do the case structures. I have 3 inputs from a Measurement Computing DAQ and I am trying to get them to plot onto an excel spreadsheet. I have gotten it to work, but now what I want to do is add a record button so that I can run the program without it logging data until I hit record. I also want the spreadsheet to have labels for each input. I have attached my file and I am looking for advice on how to setup the case structure with the record button and names for each input.Block Diagram.PNG
(1,269 Views)
Hi Devenp,
What about placing the case structure around that WriteFile function when you want to en-/disable recording the data!?
(1,266 Views)
I hadn't thought of that. I tried it and it seems to be working. Is there a way to name each input in the excel file? Right now it just says which input, but I want it to have a name such as "intake pressure"
(1,247 Views)
Accepted by Devenp
Hi Devenp,
Sure.
Read the LabVIEW help, especially on this waveform datatype. It allows for handling "attributes" and there are pre-defined attributes used by NI functions like your ExpressVI. One of those pre-defined attributes stores a label for the waveform…
(1,243 Views)
