07-13-2012 02:36 AM
How can i capture live image from my laptop integrated webcam using LabVIEW ?
Even after installing all the IMAQ drivers, MAX is not displaying my integrated webcam ?
Why is it so ?
do i need to install some additional drivers for this ?
07-13-2012 03:02 AM
I think it is IMAQdx you need to install.
At least it works for me with IMAQdx on my HP laptop :
Epictetus
07-13-2012 05:51 AM
Are you using the Integrated webcam of your laptop ?
external webcam is being detected but the integrated camera is not detected even after installing the IMAQdx
07-13-2012 06:04 AM
Yes, this is the integrated camera.
What's your computer?
Epictetus
07-13-2012 06:15 AM
it is HP Probook.
07-13-2012 06:20 AM
Hmm.. mine is HP EliteBook 8460p and it work just fine... what version of VAS (Vision Acquisition Software) do you have?
Epictetus
07-13-2012 06:28 AM
I am using the device driver software of NI developer suite 2010
04-16-2013 06:06 PM - edited 04-16-2013 06:07 PM
hi, you can use NI Vision Assistant
IDE ofNI Vision Assistant
..select acquire images
...select option 2
...select devices: CAM0 (default webcam), video mode resolution
...option 1 acquire single, option 2 acquire continuous
04-16-2013 07:14 PM
hi, you can use NI Vision Assistant can also check out the following post on the forum, has example codes that can be useful
http://forums.ni.com/t5/Discussions-au-sujet-des-autres/webCam-USB/m-p/718481/highlight/true#M21725
06-30-2013 02:14 AM
Example using a webcam and the module NI Labview IMAQdx
