03-15-2012 12:40 AM
Using a usb-6008. Using a custom scale for ai0 works fine (input).
But I get the "Custom Scale Does Not Exist" error when using the same scale with ao0. Seems to work fine if I don't use a scale.
Tried creating the scale within the code as well as setting it up within the project. Neither works.
03-16-2012 02:40 PM - edited 03-16-2012 02:41 PM
Hello Jed,
Have you tried following these steps?
http://digital.ni.com/public.nsf/allkb/2DDF9EB699D63B4386256F0400675F69
03-16-2012 03:09 PM
I believe I tried this- but the error is not a range error, the error is "The scale does not exist".
I know it exists, because during my troubles I tried using the same scale I was using for an AI task (just to see if it detected it) and this would not work (the ranges are valid in both scales, either direction).
03-19-2012 02:44 PM
Hello Jed,
Can you share the VI you're using?
Can you also share your custom scale?
This way I can try to reproduce the behavior at my side.
You can export a scale by following these steps:
http://digital.ni.com/public.nsf/allkb/42A2D212796B3DC2862571FF0061B402
03-19-2012 02:45 PM
Hello Jed,
03-19-2012 02:50 PM
