Cannot use 2 channel from NI9215 module
Hi, I am Afif Bimaridi, currently studying in Korean National University of Transportation.
I need to acquire two different voltage signal from NI9215 module and made this program.
however it shows error message when I run this program, shown in belom picture
Is it impossible to use 2 channels in 1 module?
I tried different kinds of acquiring signal method but same error messages appear.
I would be Really grateful if someone could give advice.
Thank you..
(633 Views)
Accepted by topic author afifbimaridi
Hi afif,
Place both channels into just one (1) DAQmx task!
using LV2020 on Win8.1+cRIO
(627 Views)
When you get an error message, it often helps to search the forums or even through Google before posting a question.
Search for "error 50103" and you'll find thousands of messages with the same question giving the same answer.
(It helps to leave the negative sign from the error in a search since most search engines would treat error -50103 as a search for messages with "error" but without "50103"
(573 Views)
wow thank you for your help, I'll try
(512 Views)
