06-14-2017 10:20 PM
I created network shared variables on one PC and deployed the library. Then on a separate PC (which is on the same network host), I created a new project and tired to bind new variables to these ones using aliasing. However when I tired to browse with PSP, I could locate the first PC but it did not show any network shared variables. Kindly suggest me what can I try to solve it.
Best Regards,
Shah
06-15-2017 12:19 PM
Hello svds
Have you tried to use the Distributed System Manager in order to see all the variables in the network?
http://www.ni.com/download/ni-distributed-system-manager-2015/5471/en/
06-15-2017 05:32 PM
I monitored them using distributed system manager, however, the variables created on computer show up under Network Items->Computer name. But they do not show up when I try to view them through other computer using Distributed system manager.
Shah
06-15-2017 06:58 PM
Hi, you may need to configure your firewall on the machine hosting the variables. see here: http://www.ni.com/white-paper/12402/en/
It is worth disabling your firewall briefly, just to see if the firewall is the issue.
06-18-2017 11:53 AM
Hi Michael,
Disabling the firewall worked with following observations:
1- I only need to disable firewall on the PC that publishes the variables. The one receiving it can have the firewall ON.
2- The method recommended here http://www.ni.com/white-paper/12402/en/ , did not work. I created the required file and changed the number of ports to search from 100 to 1000. The issue persists.
I guess I need to look more into accessing labview through Firewall. Thanks a lot for your advice!
Shah
06-18-2017 12:24 PM
I looked back and found i emailed NI, here you go : Shared variables require port 2343 to be opened for UDP and TCP as can be found
here:
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/psp_firewall/
I have asked NI to update the document. And you are right, these settings need to be added to the machine serving the variables.
I hope that works for you. Michael.
06-22-2017 06:27 PM
Hi Michael,
Sorry for delayed response. It turned out that I ONLY had to put exceptions for tagsrv.exe and lkads.exe in my windows firewall. I did not had to change any TCP ports etc, I only had to enter new rules for these two files in the inbound rules of firewall. Thanks for your support.
Shah
07-25-2018 09:54 AM
Same problem and this was helpful, solved my problem.
Thank you
