In one step of my application, one button dialog pops up to ask test operator to push a button. After the button push, the test operator needs to click OK button then the program will continue.
I'm wondering whether there's a way to cancel the dialog after the program detect the button is pushed? Any suggestion is welcome.
Instead of the LabVIEW one button dialog, write your own vi that pops up as a dialog box (set that using File ->VI Properties -> Window Appearance) and then you can use whatever conditions you like for deciding when to exit.
