Can you record sound using a USB 6211 and convert the data to a .wav (or other sound) file?
I am trying to build a system that will use a USB 6211 to record sounds from multiple electret microphones and then save the data as a .wav file or other sound file.  I have already built my mics and hooked the mics up to the USB 6211; the DAQ device seems to do an adequate job recording the signal - I've recorded from 3 mics at a time at 11,025 Hz, although I don't know how good the signals are since I can't save them for playback after the fact, and they aren't going through my sound card. Ultimately, I would like to save the data as a multichannel audio file which I could then open in a program such as Audacity for further editing and analysis. Since Audacity can import a variety of sound files, my file format doesn't need to be .wav if another format would work better.
Any advice would be appreciated.
Thanks, Eric
(3,016 Views)
More specifically, sampling rate is 11,025 samples/sec.
(2,984 Views)
The USB-6211 should work fine if the mics are providing a decent signal.  Have you tried the Sound File Write.vi?  It takes waveforms and a file ref and stores the data in WAV format.  Post your code if you can't get it working...
EDIT: BTW, the Sound Output Write.vi should also allow you to monitor your mics through the PC's soundcard.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,977 Views)
If you are sampling all three simultaneously, your highest frequency recordable will be (11,025/2)/3, so about 1800Hz and that will pretty coarse (traditionally digital sound recording is at 44Ks/s at the low end). As to converting to a .wav, there are functions on the "Graphics and Sound" palette for saving waveforms to a .wav file.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,973 Views)
