Can you recommend a bettery way to unbundle this cluster?
Can you recommend a better way to unbundle the cluster shown below?  There is a boolean data type in the cluster along with the doubles so converting
it directly to an array does not work.  Is there some way I can unbundle a certain number of the cluster elements and convert those directly to an array?
For instance, cluster elements 0 through 30 ?
Dave
Message 1 of 15
(4,904 Views)
Use this function
Cluster To Array Function
Owning Palette: Cluster, Class, & Variant VIs and Functions
It will take you cluster and transfort into a array
Message 2 of 15
(4,896 Views)
If you want to have only the first 30 elements as dbl, can you put into a cluster inside the mains cluster?
Message Edited by CFiset on 11-16-2009 12:53 PM
Message 3 of 15
(4,895 Views)
Since you have that pesky boolean, try this (using flatten to string).
Message Edited by Darin.K on 11-16-2009 12:50 PM
Message 4 of 15
(4,892 Views)
I like Darren's solution (kudos Smiley Happy), and it can be made to work with your original method.
However, if you can change your original cluster into a cluster of clusters, and put the "pesky boolean" in its own cluster, then Cluster to Array works fine...
Message Edited by Broken Arrow on 11-16-2009 01:04 PM
Richard
Message 5 of 15
(4,867 Views)
Can you change the boolean to a 0, 1 numeric and include it in the Cluster?  Then Cluster to Array.  Just index it out or use Split array.
Lynn
Message 6 of 15
(4,857 Views)
Oh Darin is none other than Darren ?
Message Edited by Mathan on 11-16-2009 01:08 PM
Message 7 of 15
(4,847 Views)
I presented my solution in the spirit of cleaning up somebody else's dirtywork.  If that cluster is your own creation, please consider reworking it.  And if it is your own handywork, at least you were sensible enough to make it a typedef so the conversion will be a piece of cake, right?  Smiley Wink
Message 8 of 15
(4,840 Views)
Ooops. Smiley Surprised Sorry 'bout that Darin.
Richard
Message 9 of 15
(4,826 Views)
Thank you all!  I am going to go with the cluster inside a cluster idea but I still appreciate seeing yours Darin.  It's great to see these perspectives on solving LV problems.
Dave
Message 10 of 15
(4,818 Views)
