Can you make a control (numeric/string/Boolean) appear and disappear with just one Boolean action?
Hi All,
Lets say I have a specific set of controls (1 & 2) for specific situations (A and B); so for situation A, controls A1 and A2 are required and for situation B, controls B1 and B2 are required. If I am in situation A, I want the controls for situation B to disappear from my front panel.
Attached is a tester VI I was messing about with trying to accomplish the goal stated above...but I am either missing something (I am getting an alternating appear/disappear action on the controls) or I am trying to do something that is not possible in Labview. I have also included the Labview example code I was trying to follow. The example uses a two step process to accomplish what I am trying to do; I would like to know if that process can be carried out in one step instead of two. Thank you in advance.
(3,108 Views)
Accepted by topic author yoshi123
Easy to do.  Set the controls visible property to False to hide the control or True to show it.  A transparent Tab container is another option but, I hate Tabs.
"Should be" isn't "Is" -Jay
(3,094 Views)
I'm afraid you "over-thought" the problem.  Your code (and the Example's code) changes the visibility -- you want to set (or clear) the visibility.  In mechanics, it would be mixing up velocity and position.  In the "A" situation, set A, clear B (i.e. only write the Property Nodes -- you don't care what they were previously).
(3,082 Views)
If you group the controls in a cluster, you can show\hide all controls with only one property node (EDIT: the visible property of the cluster)...
(3,061 Views)
Thank you all for the replies. I definitely "over-thought" it!
(3,037 Views)
