Can we make template editor as a control??
Is it possible to give template editor as a control ?
(2,816 Views)
I'm confused. Do you mean a control template? You can do this, I believe you right click the control and choose advanced ->customize. Then you can save the control with extension .ctt (I think that's the extension) it will be a template.
(2,810 Views)
In Vision Assistant If we take Some Tool eg. "Geomatric Pattern Matching"  in this Tool there is a template editor window.
In that window there are different types of parameter which ar setable eg."Thresold"...
So, My point is I want to give that window in Front panel.Is it possible or not ?
If Possible then how???
I attached a screenshot of Template editor Window.
1.bmp  and 2.bmp that I want to give in Front panel in vi
(2,786 Views)
