04-24-2019 01:40 PM - edited 04-24-2019 01:41 PM
I am using DSA Card PXI-4464 for my AI and have a PXI Mux Card 2575. So my question is can we do handshaking between the MUX card and the DSA Card, like the example provided which will do handshaking between DMM and the MUX card?
Thanks!
04-25-2019 05:12 PM - last edited on 01-08-2024 11:15 AM by migration-bot
Hi Rajesh,
The example in LabVIEW is specifically for the DMM and Switch card it won't work for the DSA module. However, you could use the DAQmx blocks with a DSA card to produce a piece of code that works in a similar manner. The most important piece to consider is you will need to have a Retriggerable DAQmx task, which you can see how to do in this tutorial.
Best Regards,
04-29-2019 08:01 AM
Okay Thanks Casey. Let me try that.
