03-14-2006 01:47 PM
03-14-2006 03:46 PM
Hi
You can easily change the bitsize,
First determine the maximum in the array (a function exists in the array palette)
the make sure that this max is divide so that the result is less thaan 6435 for 16 bit and less than 255 for 8 bit.
divide all the values by that divider and put them into an indicator array with the correct bitsize.
To get diifferent timing you have to undersample, in fact what you need is a sample each 1/44.1KHz instead of each 1/95kHZ
So less than halve of the samples are needed. try to find out a nice algoritme for that one...
03-15-2006 08:09 PM
"how to create a wav file from 24bit 96Khz sampling rate data"
http://forums.ni.com/ni/board/message?board.id=170&message.id=173571#M173571
Just checking 🙂
Best Regards,
JLS
03-16-2006 03:23 PM
03-17-2006 12:47 PM
