Hi
I am making executable out of my VI. I wished that the window should close once we exit the program through exit button. Hence I used "Quit Labview" function from Application Control pallette. At the same time inadvertantly I have set the VI properties as "Run when opened" and also disabled "Show run button" and "Show Abort button" options. Now when I open the VI, it starts running, it doesn't show run or abort buttons and when I press exit button to quit the program, it closes the Labview. Now I am unable to edit it's properties. Can any body tell me if there is any way of editing VI properties without actually openig the VI? Thanks and regards.
Sreedhar Nyapathi
