Can the tank indicator leave a slider at the maximum value it's read
Hello all,
I trying to use a tank to show a current level. Does it have a built in function that leaves a slider/indicator at the maximum level it's achieved? I'm sure I can use an array with a shift register and/or a local variable to store the max value but there are 10 different tanks and I'd rather not create a local for all 10 max values. Is there a different indicator that memorizes where your max value has been?
Tee
(2,815 Views)
No.  You have to program it.
(2,797 Views)
I kinda figured. Thank you for your time though.
(2,787 Views)
