Can the default DSM Hypertrend properties by changed
I would like the DSM hypertrend historical trend graphs to instantiate with default graph properties (colors, formating, etc.) of my choosing.
Is this information in some ini file that can be edited?
(2,473 Views)
sachsm,
The hypertrend graph is built into an ActiveX container, there are no settings that I know of that can change the default properties of this graph.  Two options I can think of for you are to
a)copy exiting graphs with ctrl+drag
or
b)use hypertrend property nodes to pull the settings out, and then use those to programmatically set the properties of the new graph.
I realize neither of these are ideal, but maybe they will help out. Unless someone else knows a trick I am not aware of?
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(2,448 Views)
