Can't remove a file from Project
@Ranjeet_Singh wrote:
As he says he is no remove option so I attached my project snpshot which is in LV2011 and he is using LV2011SP1. So What I want to tell him that it is available in previous version so it should be there. He never mentioned anything is broken.
I already attached image file in my previous post.
I give up.
Message 11 of 17
(3,966 Views)
Don't give up!
Rangeet a picture is not source code.  A minor point but, an important one when you want help.
Now, You added *.LLB members to a *.lvproj.  DUH! (Facepalm) the vi's are members of the library!  Convert the llb to a project of folder Then add the vis THAT NO LONGER THINK THEY ARE LIBRARY members to the project.
(Snapshot folder abuse thread? anyone?....)
"Should be" isn't "Is" -Jay
Message 12 of 17
(3,921 Views)
@JÞB wrote:
Don't give up!
I attached my project file becasue he had problem in snapshot folder.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 13 of 17
(3,905 Views)
Yeah- snapshot folder.
Now, smack your forerhead  !!!!!!
how do you want those of us without your llb to help? you
We Can't  redirect llb members for you!
LLBs are flat!  how did you expect a "Snaphot" to work? when attemping to pull a outdated llb into moderen projects?
(Heck, why do you even have AN LLB?)there are better constructs!
Did I embarass you enough?
Yes, I get these questions often.   try to keep upSmiley LOL
Message 14 of 17
(3,902 Views)
He was facing problem in deleting the file which belongs to snapshot folder so I attached related to that only.
--Ranjeet
Message 15 of 17
(3,896 Views)
If you read the original question again (or some of the other related comments in this thread), you can see that he already knows where that right-click menu entry is supposed to be, but it does not show up under his exact scenario. Even 1000 pictures of a menu showing the option will not be able to make this entry magically appear for him.
Message 16 of 17
(3,890 Views)
Thats what I mean to say is I am using LV2011 and he is LV2011SP1.That option is displaying in my project so it should come there.
What I mean with that image file is in lower version of labview it is avaliable so it should be there in his labview. I just showed him that. But it was not coming so I want him to check other things. Later he told some rename he did, in that I told him that may cause a problem.
--Ranjeet
Message 17 of 17
(3,884 Views)
