Hello!
I have XY graph that I want to print on the whole page in landscape orientation (paper A4).
On the screen the graph is small, so I do resizing, appending image to report, and then printing.
After sending it to the printer I get preview (from the printer software) and see that the graph uses only approx. 5/6 of the page in the width, in other words the height of the graph takes the whole height of the page (21 cm) and the width of the graph leaves 5 cm of the page unused.
I tried to change the width and the height of the plot area to get proper ratio, but in vain.
If I set the height of the graph too large it goes beyond the page, but whatever I write to the width I always get 5 cm of the page unused on the right side. (not including 1 cm of the margin).
Note: surely, if you set small width you can get more space of the page unused, I'm talking about increasing the width of the graph.
Any ideas?
See attached for the vi. I tried to save it for 7.1 version but it can't, so you'll need LabView 8.0 to check it.
Also in attached you can find the page preview I get before it goes to printer.
Thanks in advance.
Rashid.
Using LV 8.0 Pro on WinXP with printer Canon PIXMA iP1000 (also tested on HP printer, but I think it doesn't matter).
Message Edited by Rashid on 06-06-2006 07:09 AM
