04-14-2009 10:55 AM
Hello Board,
I have loaded & un-installed and re-loaded NI 488.2 version 2.6 on two new pc's running XP. Max opens up and sees the connected harward after scanning as usual, but when I try to open NI-Spy to monitor the calls I get ?Clone@cNISPYLog210@@UBEPAVINISPYLogger@2N@Zcould not be located in the dynamic link library. NISpyLog.dll." I have loaded NI-488.2 on several other pc's and this is the first time I have sent this error. Am I missing a file in my NI-Spy folder or do I have something missing in Labview? I am using version 7.0.
04-15-2009 05:51 PM
Hello tryn,
Can you post a screenshot of the error message?
Also, I found a KnowledgeBase article speaking of a similar error with a different driver. Take a look and see if following these steps for your driver shine any light on the matter. I have attached a screenshot of all the nispy dll's on my system along with their location. Go through and ensure that you have exactly one copy of each of these files.
04-15-2009 07:25 PM
Hello Peter,
It appears the NI-488.2 disk was corrupted. Max ran fine and all the Ni-Spy dll's appeared to be loaded, but the executable wouldn't open. I loaded a seperate disk and repaired and now the Ni-Spy executable runs properly.
Thanks for the help and response
