05-26-2006 01:52 PM
05-26-2006 02:08 PM - edited 05-26-2006 02:08 PM
Message Edited by Novatron on 05-26-2006 03:08 PM
05-26-2006 03:55 PM
Novatron,
Thank you for your rapid responce. I have attempted to follow your suggestions with no success. I did save the "build array" and move it inside the loop to bring the 3 data streams together. I then enabled indexing and had the same results as before, one row three columns. You are correct that what I am getting is the last data point when the program is stopped. I will attempt to attach a screen shot if that may help better understand what I am doing, however this hasn't been working when I preview the post. How do you attach the jpg on the screen?
Again thank you.
05-27-2006 10:21 AM
