12-09-2013 02:26 PM
I am trying to run an example code, provided by the manufacturer with a Keithley 2420 3A SourceMeter. It is powered on, and set up for 488.1 GPIB Protocol. It is hooked up to my computer using a KUSB-488A GPIB cable. On the front panel of the example program, there is a drop-down menu labeled "VISA resource name." The two options available to me are LPT1 and COM1, but I don't think either of these are the right resource name. Does anybody know what VISA resource name I should be using with the Keithley, or how I can find this out? If it helps, I provided the example program I am using. Thanks in advance!
Solved! Go to Solution.
12-09-2013 02:37 PM
Start by opening NI-MAX and see what ports are recognized under 'devices and interfaces'.
12-09-2013 02:45 PM
Typically, only NI hardware is going to be recognized in MAX and you would not get any VISA resources for non-NI controllers. If there is a VISA driver for the Keithley, you can try installing that as a secondary VISA driver and enable Tulip support in MAX. Keithley support is the best place to ask about installing their hardware for LabVIEW.
12-09-2013 02:55 PM
If you read the intructions that come with the Keithley USB-GPIB converter they enclude installation instructions to install the National Instruments compatable version of their driver.
Yup, just read and follow the set-up instructions.
12-16-2013 11:29 AM
I figured it out, I realized I need a driver for both the instrument AND the connecting cable. Who woulda thought?
