Can't find 73xx
Hi everyone! I'm in a weird situation. I've setup my LabView 2013 according to the procedure with every function I can download, but when I open Vision and Motion, I can't find 73xx function. I really don't know what went wrong, is it posible to get that function without installing the whole thing again?
(1,668 Views)
When installing NI-Motion, activate the support for 73xx interfaces.
(1,657 Views)
To add on this, when installing NI-Motion, the installer should detect which versions of LabVIEW are installed on your computer.  Be sure to check the checkbox to install support for your LabVIEW version, as this will install the NI-Motion VIs into your palette set.  If you don't see the VIs, try installing NI-Motion again, and the VIs will show up.
Another tip, be sure to check which version of NI-Motion you need for LabVIEW 2013.  See here: https://www.ni.com/en/support/documentation/compatibility/17/ni-motion-and-labview-compatibility.htm...
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source NI hardware? Try NI Trading Post
(1,600 Views)
