10-19-2009 06:51 AM
I use configuration file VIs in order to read different value from a *.ini file.
I use it to store string data that I send through a serial port. I have normal formatted ASCII string (ex: “START”) but also ‘\’ code formatted ASCII string (ex: “\3A\01\02\03\FF\AF”).
It works in LabVIEW 8.6, the ASCII numeric read values are the same and they are correct on my front panel when I display them in ‘\’ code.
In LabVIEW 2009, when I read a string value which is written in '\' code the character '\' is doubled for the value over \1A (ex: “\\3A\01\02\03\\FF\\AF”).
Is it a bug or a limit of LabVIEW 2009?
Jeremy
Solved! Go to Solution.
10-19-2009 07:13 AM
Can you include your code? Does it work in 8.6 with exactly the same code?
10-19-2009 07:30 AM
10-19-2009 07:41 AM
10-19-2009 08:22 AM
In my examples I try to retrieve my initial string which contains only 5 characters ("\3A\BF\01\FF\05").
In LV 8.6, this string in normal display shows nothing very useful because the characters don't correspond to full displayable character.
The '\' code display contains the following string : ":\BF\01\FF\05" because 0x3A is the hex value of ":".10-19-2009 09:15 AM - edited 10-19-2009 09:17 AM
I think the point the OP was raising is that the result is DIFFERENT in 8.x and in 9.0
The string in question comprises 5 instances of a \xx escape sequence, aach representing a single character.
I tried reproducing this:
In 8.2 the result string from read key is 5 characters long, and consists of the equivalents of the 5 escape sequences in the .ini file.
In 9.0 some of the \xx sequences are NOT converted, so the resulting string is 11 characters long.
I've looked into the parser vi that converts the string which may contain escape sequences into the result string,
<LV dir>\vi.lib\Utility\config.llb\Unescape String.vi
It would apear that 9.0 is stricter at what it allows in the escape sequences. In 9.0, an escaped character of the form \xy is only recognised in 9.0 if x is 0 or 1, and y is a hex digit (A-F must be in Upper case) -- Open the vi, [you can drill through the confin file VI's as they're not passworded] and you'll see the the VI looks for a match pattern of "^\\[01][0-9ABCDEF]" to see if it's an escape sequence.
In 8.x, the routine was rather different, and both x and y were any character acceptable to "hex string to number"
In both revisions the routine to convert INTO the \xx escaped form would only convert characters whose value is 31 (decimal) or less, and always use upper case for A-F, so would always produce sequences that both 8.x and 9.0 will read.
So ..... if you use just NI's routines to convert the string into its escaped form before writing, you're OK, but if you did you own escaping, you'll need to read the string in raw format and do you own unescaping, (or pinch the LV 8.x unrescape routine)
Rod.
10-20-2009 02:38 AM
I finally fix my problem by modifying the Unescape String.vi in <LV9 dir>\vi.lib\Utility\config.llb.
I change the match pattern constant string from "^\\[01][0-9ABCDEF]" to "^\\[0-9ABCDEF][0-9ABCDEF]".
Thank you for your help
