10-12-2009 07:48 PM
10-13-2009 04:19 PM
Howdy E=McHammered,
First off, great name. Well played. Secondly, did you just export the MAX configuration or did you specifically save/load your IVI configurations? Without this, you will run into problems trying to run any code that uses IVI calls.
10-13-2009 06:17 PM
I imported the configuration. I figured out what the problem was. It was in the drivers, I wasn't associating the driver instance with the proper resource name. The default resource name that MAX 4.5 puts in for the resource selection is rarely the one you are supposed to use. Thanks for your time though.
12-07-2009 12:30 PM
ColeTrain wrote:Howdy E=McHammered,
Hi ColeTrain,
I'm getting the same error code on a PXI-2535 from the InitWithOptions API, but I'm confused about that. IVI defines the maximum returnable error code as:
#define IVI_MAX_SPECIFIC_ERROR_CODE (IVI_ERROR_BASE + 0x7FFF)
Which ends up being
0xBFFA7FFF |
I've written scripts to scan all of the IVI and NI header files looking for matches and I couldn't find any for 0xBFFC0011. I also couldn't find any defined IVI errors that don't begin with 0xBFFA. I looked at the system configuration and it looked correct to me, so I'm hoping if I know what the error actually is I'll have a better chance of figuring out what is going wrong. Do you know the specific meaning of "0xBFFC0011" and why it isn't a valid IVI error code?
Dave Gladfelter
12-07-2009 01:51 PM
Well, I think I found my own answer. I still don't know why the init fails, but the error returned by the driver, "0xBFFC0011", comes from the VISA specification and is defined as "VI_ERROR_FAIL_ID_QUERY". I'm guessing that the error that an IVI-compatible driver should have returned is "IVI_ERROR_ID_QUERY_FAILED", which is "0xBFFA005E". Either way, the error is pretty generic, but at least I think I know what is going on now.
Dave
