Can't change bounds of ActiveX picture programmatically
Hello
I'm trying to change ActiveX container bounds using property node. But change to read for the bounds property is disabled (grayed). I've download the example, where container's size changed in such manner, but I can't find difference between my ActiveX object and the one in the examlpe. Any ideas?
(3,239 Views)
Do you mean Change to Write?
You are probably trying to work with GObject:Bounds which is Read-Only
http://zone.ni.com/reference/en-XX/help/371361B-01/lvprop/gobj_bounds/
But you want to work with ActiveXContainer:Bounds which is Read/Write.
http://zone.ni.com/reference/en-XX/help/371361B-01/lvprop/activexcont_cont_bnds/
Hope this helps
David
(3,235 Views)
Sure, Change to WriteSmiley Happy I was trying to change GObject:Bounds Smiley Happy Thank you
(3,226 Views)
