10-01-2011 02:58 PM
You can use a relative path your .exe to the text file. You just have to pay attention that your VI's path is different in an .exe than it is in the development environment.
Why Does My Executable Not Work When Using the Current VI's Path Constant?
10-01-2011 05:41 PM
It is easy to adjust for whether or not you are running in an executable. Here is a VI that does exactly that. Give it the path to the current VI and it will return the folder that it is in and adjusts for whether it is in an executable.
Rob
10-01-2011 08:10 PM
You didn't provide a text file, but I created one and again, if it is in the same directory as the EXE, the porgam finds it and loads it up. It parsed all the data correctly. There's still something missing. From your code posted, I have Application.EXE and the VIDAQ Configuration File.txt in the same directory.
10-01-2011 08:12 PM
It may also help to use the simple error handler VI to tell you exactly the error you are receiving. Right now, you are ignoring any errors.
10-01-2011 08:28 PM
My apologies, you did include an example file. And it as well works if in the same diretcory as the EXE.
10-02-2011 11:22 AM
Had to strip off "THREE" Levels rather than two levels for Windows XP.
You live and learn.
I've enclosed the programmed application with the various levels of directory at the bottom on the first slide.
The second slide show the executable and its levels of directory.
10-02-2011 11:48 AM
You live and learn.
Check your build specification. It looks like the build specification is putting extra folders in the destination.
I always change where my build goes. Usually: C:\<project folder>\builds.
When I worked in WinXP, I only ever had to strip one more level than when I was working in the development environment.
Rob
10-02-2011 12:05 PM
Rob,
Doesn't seem to help. It's that pesky .exe file I have to strip away. Don't know what a .exe file is doing in the path.
Mark
10-02-2011 12:08 PM
Did you read the link I posted? !!
10-02-2011 12:20 PM
Ravens Fan,
I'm reading it now. Looks like it has the answers I'm looking for. May take a while to absorb and check out.
Mark
