02-10-2022 09:15 AM
I'm attempting to profile my program and would like to observe buffer allocations.
However when I go to Tools > Profile > Show Buffer Allocations... the options is grayed out. I can't seem to select it / run this tool no matter what I do.
Is there some trick to this that I'm missing?
Thanks in advance!
02-10-2022 11:18 AM
What's your LabVIEW level (Base, full, pro, etc.)
02-10-2022 11:43 AM
I'm currently running:
02-15-2022 06:51 AM
Any idea why this option may be unavailable to me?
Or steps for me to be able to use this tool?
02-15-2022 07:11 AM - edited 02-15-2022 07:19 AM
ASSUMING: you are using the tools menu from the Block Diagram. There aren't any buffers on the Front Panel so, you might be seriously disappointed trying that there. 😉
I would suspect either that the VI properties are set to disable debugging or you have a Clone instance open rather than the VI original.
Ctrl+M would switch to the VI Original.
Ctrl+I opens the VI Properties editor. If the VI is Inlined you will have to deselect that before you can Enable Debugging.
Otherwise: Ctrl+E opens the Block Diagram unless it is protected.
02-15-2022 08:30 AM
Thank you so much for this!
I was attempting to launch the tool from the main program window, instead of from each VI individually.
