03-16-2006 03:08 PM
03-17-2006 05:04 AM
Have you installed NI DAQ Device drivers??
03-17-2006 10:47 AM
Yes, I installed the NI-DAQ devise drivers. During the setup I was prompt for adding optional signal conditioning modules which appears to be SCXI. Am I supposed to select something from here? (I skipped that step). Is the AT-MIO-16E a SCXI device?
At the completion of the NI-DAQ setup I checked to the Measurement & Automation system in the Devices and Interfaces, but there was nothing there.
03-17-2006 10:59 AM
What version of DAQ did you install? That is an older card that is supported by an older version of DAQ.
Also, I think you are supposed to install NI-DAQ software before you install the hardware. You may want to try powering down, removing card, powering up then down again, and reinstalling the card. May be worth a shot.
03-17-2006 11:35 AM
03-17-2006 11:51 AM - edited 03-17-2006 11:51 AM
Message Edited by Dennis Knutson on 03-17-2006 10:52 AM
03-17-2006 12:12 PM - edited 03-17-2006 12:12 PM
Message Edited by Jonnie 5 on 03-17-2006 01:13 PM
03-17-2006 03:55 PM
03-17-2006 04:17 PM
03-21-2006 01:56 PM
