Can someone convert this LV 8 vi to LV 7?
So I saved this for 7.0, but there were some issues when saving it, due to VIs you were using that werent in 7.0. One of them was the "space constant" which I replaced with the "blank string constant".
Let me know if this works enough for you to get going.
Claire Reid
Message 11 of 29
(1,987 Views)
Thank you very very very muchRobot Happy It works good, I made only small changes. Claire, you are the bestRobot wink
Gabriel
Message 12 of 29
(1,970 Views)
Can Anyone please convert this vi file belonging to Labview 8 to labview 7.1. Thanks a Lot !
Message 13 of 29
(1,922 Views)
Hi mecsumit,
here you go. You have to rework some parts as the mixed signal graph of LV8+ doesn't exist in LV7.1...
Btw. the graph was connected after the build array node!
Message Edited by GerdW on 01-13-2010 08:09 PM
Message 14 of 29
(1,909 Views)
Hi: I also have the same problem. Would you please convert the vis in this zip file to Labview 7?
Thank you very much
Message 15 of 29
(1,844 Views)
Hi visatimeout,
here you go... (I put all the VIs from the llb into a folder for future safety Smiley Wink )
Message 16 of 29
(1,839 Views)
I, too, would like to have a LV8 VI saved for use with 7.0.  Any help would be greatly appreciated.
Eric
Message 17 of 29
(1,740 Views)
Hi Eric,
it would be nice to mention that your VI is LV8.5 instead of just "LV 8"...
Maybe you will have problems  running the VI, as I didn't have the needed .NET structures on my computer...
Message 18 of 29
(1,718 Views)
Thanks, and sorry for the incomplete description.  Unfortunately, I still can't open a VI saved in LV 7.1 with my version 7.0 (and cannot update to an out-of-date LV version).
I have attached the VI from LV 8.5 again, and wonder if anyone can open it in LV 8.5 or later, and save it so that I can open it using LV 7.0.  I would very much appreciate the time and money it would save me not to be forced to update my whole system for this one small subVI.  Thanks very much in advance.
Cheers,
Eric
Message 19 of 29
(1,659 Views)
I need to use this file with LabView 7.1. I saved it in LabView 8.0 (I use The 8.6 release on my laptop, and the 7.1 on the other computers).
Thank you.
Message 20 of 29
(1,650 Views)
