06-09-2009 10:45 AM
Hello everyone!
I am not a LabView King (yet) .... but I have some skills in programming in other areas. I have been playing with a few programs on multiple PCs and came to one particular PC where I am unable to view "properties" on anything within the program. I can edit the program all I want ... but when it comes to a "right-click" and a "view properties" ... i get an hour glass (for a second) ... and then nothing. Hmmmm. Any ideas out there. The problem occurs on ALL programs on this one PC ... so I was thinking there might be some .dll file or something missing from the LabView installation ... but I really don't want to go through a re-install until I know for sure. Is there some option I am missing that would cause such a headache to an eager learner as me?
06-09-2009 01:12 PM
Has anyone seen this problem before? Suggestions? Ideas? Maybe my original message didn't explain the problem clear enough? Help(?) 🙂
06-09-2009 01:30 PM
06-09-2009 02:03 PM
06-09-2009 03:24 PM
06-09-2009 03:30 PM
Is it possible that you moved the dialog box off to the edge of the screen and then changed monitor settings such that it now is hidden off the screen?
Check around the edges of the screen to see if a 1-2 pixel edge of the properties box is lurking somewhere.
Lynn
06-09-2009 03:42 PM
06-09-2009 06:11 PM
Which version of LabVIEW are you using?
(did I miss it?)
06-09-2009 06:12 PM
06-09-2009 06:26 PM
no hating, LV7.1 remains one of my favorite versions.
I occasionally still use it.
Can you post your vi and we can have a look at the properties of objects? Let us know which object you look at that cause problems.
R
