04-29-2015 03:06 AM
Hello
my uEye camera is shown in MAX and it is working. Now I would like to set a specific ROI in order to have a higher camera frame-rate (fps). Under the tab "Acquistion Attributes" I can set the
ROI but unfortunately it is greyed out!
The video mode shows some default settings for different resolutions but I need to set the resolution independent. How can I do that?
Thanks!
04-29-2015 04:38 AM
Are you able to change the width and height?
04-29-2015 04:40 AM
No - not possible...
04-30-2015 04:40 AM
Hi Norick,
as I can see when looking at your screenshot Top and Left are greyed out and Height and Width not.
What happens when you try to change the Height and Width?
Can you modify the timeout?
Andi
04-30-2015 06:18 AM
Hello Andi
although the width and height are not greyed out I can NOT change it at all. The timeout I can change without problem as well as set one of the
video modes.
regards
04-30-2015 09:15 AM - edited 04-30-2015 09:16 AM
Hi Norick,
which camera from uEye do you use?
How is it connected to your PC?
Which version of Vision Acquisition Software do you have installed?
Do you have another camera which you can connect to your PC? Can you set the ROI there?
Do you have software from uEye installed which you can use with your camera? Can you modify the ROI there?
Andi
05-03-2015 11:56 PM
05-07-2015 09:47 AM
Hello
IDS uEye USB3; UI336xCP
USB3
Feb. 2015
Same issue with other uEye Cameras
Yes, with the uEye driver I can set the ROI. Also with the IDS Labview driver I can set the ROI.
05-07-2015 09:51 AM
and...
-Can you list other possible video modes available? Try changing to different modes and see whether you can change ROI?
There are about 20 different video modes available for select. It does not mather which video mode is active, it is not possible to set the ROI inside MAX.
-Can you try overwriting the parameters manually in the camera file found in Documents>>National Instruments>>NI IMAQdx>>Data?
Yes I can but it has no effect.
-Can you write labview program and change the parameters programmatically?
Yes possible with the IDS Labview driver.
-Also check with camera vendor it allows ROI changes or not?
With the IDS driver no problem.
With the IDS driver I could solve my problem but I am still wondering why I can NOT set the ROI directly in MAX. This would be much better and faster.
11-29-2017 11:52 AM
"With the IDS driver I could solve my problem but I am still wondering why I can NOT set the ROI directly in MAX. This would be much better and faster."
Were you able to figure out how to set the ROI directly in MAX?
