Can not read text file: Error 7 file not found
      I am reading a text file (header.txt) which is put at the same directory as the vi. I use winXP & Labview 8.6. The VI reported error:
Error 7 occurred at open/create/replace file in OpenTextFile.vi.
      However, I copied the file path at the end of the error message and pasted it in the IE address bar, and I found that IE can open the file.
      Why it does not work?
Ryan
(3,606 Views)
Accepted by topic author RyanWu
Never mind. I solved it. I feeded the wrong file name in the diagram.
(3,602 Views)
You should mark this as solved so that everyone will not look at it and can concentrate on other questions that still need help.
Tim
GHSP
(3,585 Views)
