08-07-2017 03:32 AM
08-07-2017 04:01 AM
08-07-2017 04:11 AM
08-07-2017 04:22 AM - edited 08-07-2017 04:30 AM
Where is it?
If you have upload problems you might put it inside a ZIP archive…
Edit:
I guess it's the default sound file coming with Windows installation.
Even Audacity yells at it:
Conclusion: Use WAV files with default uncompressed encoding with LabVIEW…
08-07-2017 04:24 AM
08-07-2017 04:37 AM
Thanks 🙂
Do you have an uncompressed wav file? I would like to try.
Or is the a way to fix an conpressed file?
08-07-2017 04:43 AM
Hi Michael,
You can use Audacity to create WAV files. It's free to use…
Search for a conversion tool that handles compressed WAV files…
08-07-2017 05:18 AM
I downloaded Audacity and found that "chrimes.wav" is can be imported and played in Audacity.
My VI still don't run though...
08-07-2017 05:47 AM
08-07-2017 05:49 AM
good for you 🙂
