Hi,,
I want to measure the RPM ( rotation per min ) of a roller by using photomicrosensor of Omron. The output of the sensor should be pulse waveform. If I could measure the frequecy of the waveform , I will know RPM.
However, the pulse waveform I got that has noise thus i did compare the waveform applitude ( Voltage ) with constant value in order to cut the noise, then rebuit the new waveform that its waveform voltage is real pulse.
But I can not measure the frequency althought I used some tool such as Tone Measurement...
The attached file below is my program.
Please help me .
