10-09-2017 08:15 PM
Hello
I have installed Labview 2017 evaluation version, and, subsequently, NI-DAQmx software. However, I can not find "NI-DAQmx Data Acquisition" icons in Measurement I/O palette of Labview program. I wonder what is the problem and how may I solve it? Thank you very much!
Best regards, Xing
10-09-2017 09:31 PM
What version of DAQmx did you install? It should be 17.0.
10-09-2017 09:47 PM
Thank you for your asking. My labview is 17.of1.
Do you know how to solve this issue? Thanks.
10-09-2017 10:02 PM
My question was the version of DAQmx. You already stated you had LabVIEW 2017. If you installed anything before DAQmx 17.0, then LabVIEW 2017 will not be supported.
10-11-2017 11:18 AM
Labview does not like older drivers in the computer when installing 17.0. Remove old drivers and install the 17.0 version. You have to reinstall the 17.0 Daqmx drivers, it did not install properly. That should fix it.
