04-09-2010 07:54 AM - edited 04-09-2010 07:55 AM
I am trying to build my host VI on a crio9074. About half way through the build it hangs up while "Saving niFpgaDmaChannelImplementation.ctl". It then hangs there for about 10 minutes and then I finally get a error that the build failed with this message:
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_RTEXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCallerMethod Name: Save:Target Instrument
Happens consistently every time, so I am stuck. I searched and the control mentioned is in one of the LV support directories. The VI I am trying to build does use FIFO reads to communicate with the FPGA.
Solved! Go to Solution.
04-09-2010 11:49 AM
