03-06-2019 01:56 AM
Now I can get a GSM signal from SG, And I want to compare the signal from SG with the signal generated by Labview.
So I want to ask 'Can labview simulate generating a moduleted signal? '
03-06-2019 02:11 AM
What do you mean with SG? Signal generator I assume? Of course Labview can generate a modulated signal. You can build it with a with a waveform. But for what purpose?
03-06-2019 02:37 AM
Thank you for your answer.
1、Yes,SG means Signal generator.
2、You said I can build a modulated signal with a waveform,Do you mean I can get the signal without connecting the hardware?
3、I want to compare the signal of Signal generator with the signal of labview.
03-06-2019 02:39 AM
