Can i use multiple cdaq 9205's on the same pc?
I am using a 9205 to monitor a piece of manufacturing equipment. The labview application is currently running on my workstation which is not ideal. I want to do two things:
  1. Set up a rack mounted pc dedicated to running the labview application.
  2. Expand this program to multiple manufacturing work centers.
I First tried running a virtual pc on a server. This doesn't work. The labview app needs access to the bus.
My current thought is to purchase a rack mounted pc and install the labview app on it. I would set the pc to auto start on power up,  app to autostart and auto run on boot.
Can I run more than one app each collecting data from its own 9205 chassis?
Can a single pc collect data from more than one cdaq chassis simultaneously?
(529 Views)
  • Yes, you can, as long as those instances of the Applications do not clash for the same resource, whether it be communicating with the same DAQ or reading/writing from same file.
  • Yes, each instance of the application has to know which DAQ it has to control/acquire data from - always each instrument will have a unique identifier (alias)
Santhosh
Soliton Technologies
(525 Views)
