Can i control two TDS 420A Osilloscope at the same time?
Hellow!
Is it possible to control two or more TDS 420A Osilloscope at the same time? i have tried the"TKTDS read waveform.VI" ,it is OK for one osilloscope,but when i connect two Osilloscope,it will not work,so are there any way to do it? thanks!
Message Edited by happybird on 06-09-2005 01:21 PM
(2,570 Views)
I assume that you are communicating with them through a GPIB bus using VISA. If so, make sure that they have different addresses. You cannot have two scopes on the same bus with the same address. I've tried :).
Let us know if any of my assumptions is incorrect as well.
Hope that this helps,
Bob
(2,562 Views)
You are right,now i change the address of one osilloscope,the problem has been fixed,thanks!
(2,555 Views)
