Hi to all labview users... Please help me with my deadly problem. Last Deadline is on monday next week!.
I got a complete program now, written and tested OK. It communicates with a slave to control a motor. I've set up the program to communicate with the slave by the VISA RS232 Serial Port commuication. and all works fine...
Now the problem is.. that The communication should have been by the USB port instead. So what I have done now, is that i used a USB to RS232 converter. So that the USB Plug is plugged to the PC, and the RS232 end to my SLAVE,
When I send a command to my SLAVE, the SLAVE seems to understand it and it executes the command. But I must read some data at the port after sending my command to the SLAVE, coz, this command ask the SLAVE to start streaming data to me.
All communication to me from the Slave crashes so that i get ( sometimes if I get data ) wrong unknown data i cant understand.
So the big question is: Can i use USB communication although my Application is set up with serial communication if I use a USB to RS232 converter??? ( the Driver for the USB - SERIAL conv. is installed well.)
Baudrate :115200.. parity : none, Data bits: 8, stop bit : 1.
Please help me.....
Hassan Zamzam
Pictures attached
HFZ
