Can a file be replaced without permission?
I'm writing a string to file using the Write Characters To File.vi, however I do not wish to be asked if I want to replace the file. Is it possible to replace the file without permission?
(2,619 Views)
Open the Write Characters to File.vi and save it as another name. Look inside of your new VI. Inside is an open/create/replace file.vi that has an advisory dialog? (display = T) terminal. Wire a false to this andy you should be good to go. I would not change the original, though.
Hope that this helps,
Bob
(2,615 Views)
