11-14-2006 02:20 PM
Is there any way to have a Combo Box control a Tab Control. An Enumerated Ring control can if all the names match "Exactly", question is can a Combo Box do the same, especially within an Event Structure?
I haven't been able to figure it out. Enclosed is a test VI that has an enumerated ring example, and a combo box with the same data. Thanks for your help...
11-14-2006 02:50 PM - edited 11-14-2006 02:50 PM
Message Edited by smercurio_fc on 11-14-2006 02:50 PM
11-14-2006 04:07 PM
Thanks for the reply, but in the real user interface the tabs are hidden, and there are several other controls on each tab. The real question is: how can i select the correct tab using the combo box as the control. ie. if I select, in this example, the combo box labeled COMMAND, to "Get CCU RX Status (R4)" then I want the tab with the same name to be selected, but is does not. Where the Enumberated ring labeled "2aryProcCmd" does select the correct tab control. I left the tabs showing just so you can see which tab is really selected. Its part of a user interface where the user can select the combo box selection and the correct tab is selected with instructions and controls to execute a specific command. It seemed to be a clean way of doing the user interface. Right now to get it to work I have to have a multiple case statement in the event structure that has the correct constant driving the tab control. So when I want to add or edit a command I have to go through all 35 cases and change the constant. Very time consuming and not very elegant.
What you indicated as the solution, I think would change the combo box from the tab control and not the other way around.
Thanks.
11-14-2006 04:24 PM
11-14-2006 04:31 PM
11-14-2006 04:44 PM
11-14-2006 05:02 PM
11-14-2006 06:03 PM
