09-10-2014 01:05 PM
Hello NI community , this is my first porst , than I spect to be clear on my question.
My problem is , there is some way to open an specific VI , RUN IT and after it's executin , CLOSE IT on a specific slide from a powerpoint file ?
I have a powerpoint presentation of DAQ automation , and when the presentation reach the specific slide (slide number 5 for example) I want to open the specific VI , execute it's functions and after that close it.
Is there any way to do something like that ?
Thank you very much.
09-10-2014 01:20 PM - edited 09-10-2014 01:20 PM
Okay the direct answer to your question is no. But then a "maybe".
LabVIEW is the only thing that can open a VI. The Run-Time engine is the only thing that can run a VI (let's assume the Run-Time Engine is part of the development environment) So no, Powerpoint can't open a VI.
But, if you have LabVIEW installed on the machine, you can call into it with a command line call to open a VI. If the VI is set to run when open, you can have it look like PowerPoint is running a VI. Something I am unsure of, is if PowerPoint can run a command line program.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
09-10-2014 01:40 PM
Hooovahh wrote: Something I am unsure of, is if PowerPoint can run a command line program.
I haven't done it, but I'm pretty sure you can have a hyperlink to a file and then Windows will try to open the file in whatever the default program for that file type is.
09-10-2014 01:41 PM
09-11-2014 04:26 PM
I wrote a slideshow program using LabVIEW. SInce LV is already "running the show," so to speak, demonstrating a VI is trivial. The code is not in a condition to share.
Lynn
