Can LabVIEW read a text file from the Internet?
I'm using LabVIEW 8.5 and I'd like to read a one-line unformatted text file stored on a web site (example: www.text.com/test.txt).
I have found that I can't do that using the standard Read from Text File subVI; is there a better way?
Thank you for your help.
Message 1 of 9
(6,602 Views)
Use the "Datasocket Read" function found under Data Communication -> Datasocket.  Wire your URL to Connection In, and an empty string to the type input.  The contents of the text file will be returned as the Data output.
Message 2 of 9
(6,586 Views)
Accepted by Arrington
Don't forget to form the entire url (e.g. starting with ftp or http).
You might also have to append the string [text] to the end of the URL. Check the help.
Here's a snippet:
Message Edited by altenbach on 02-13-2010 08:01 AM
Message 3 of 9
(6,579 Views)
Hey, that works far better than what I had so far... this version gets rid of the quotation marks at the beginning and end of the data.
Thank you!
Message 4 of 9
(6,572 Views)
I tried to read a .txt file like you suggested, bu i get en error: 1181 Protocol not recognized by LV. The file i am trying to read is on a https:// . Can that be the problem? I am using LV 2010.
Jozef Lipták
Message 5 of 9
(6,047 Views)
Datasocket does not support https, to the best of my knowledge.
Rolf Kalbermatter  My Blog
Message 6 of 9
(6,033 Views)
Is it possible somehow to read a .txt file from https:// ? Anybody an idea ? 🙂
Jozef Lipták
Message 7 of 9
(6,013 Views)
The "easiest" will be to use ActiveX and access the Internet Explorer ActiveX interface for this.
I would love to point you to a library I did last year on Lavag.org, but it needs some more work to be of use to most people.
Message 8 of 9
(6,000 Views)
LabVIEW 2010 has an SLL VI that can be used with the HTTP GET VI: https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/data-communication/protoc...
Can't say that I've ever tried this, so I don't know if it will work for you. Not sure which security protocol it uses, though.
Message 9 of 9
(5,999 Views)
